Can Any One Help? Spare Key!
depzpolo
Post by depzpolo »
I bought a S Reg 1999, Polo 1.4L about 7 months ago and it came with 2 keys, unfortunatly i've lost my spare one and currently only have one on me!
I went to a couple of key locksmiths and they told me that it has a chip inside which is programmed and can't be duplicated.
I tried many places and they all gave ago in their machinces but it just doesnt copy it.
At one locksmith, he copied the key but when you turn the car on the engine comes on but turns off again so it wasnt done.
My final option will be the VW people but i know if i walk in there they will charge more then £100 + VAT, just for a key! but then again i know if i lose this one then i will have to pay £400 for another one according to people.
Anyway if anyone know or have any ideas what should i do then please let me know as it wpuld be a great help! I live in north london!
mysteryboy
Post by mysteryboy »
just take care of the one you have
Alex_6n2
Post by Alex_6n2 »
there is no way round it mate
Off to veedub for you
at least you know your car is hard to steal :)
JTLondon
Post by JTLondon »
Is this with all 6Ns?
AKs_SlickPolo
Post by AKs_SlickPolo »
Im in the same situation mate. Ive been told, the thing with VW keys is that there is a rotating cryto, meaning the code of the chip always rotates when u start, so it cant be copied. It has to be programmed to the car via VAG-COM which a specialist could do too, as well as Vdub. Im in North London too and ive heard there are some about.
VW told me £50 for key cut, and then about £60 to programme it.
£110 for a key! lol
helios1
Post by helios1 »
£110 for a key or losing the one you have and then not being able to drive your car.... think I know which id choose. :roll:
depzpolo
Post by depzpolo »
thanks for ur advises!
M1 TCH
Post by M1 TCH »
just thinking actually.........
i had a customer who had a corsa who wanted remote start on his car.
without putiing key into his ignition, it would not start due to the chip in the key.
i got his key with the transponder (chip),stuck it to this box behind the dash..... which dissabled the cars immobiliser,as the signals from the key were constantly going to the box.
then all we did was get a cheap 3-4 quid key cut off the market and used that one if things ever went wrong.
would the polo immobilser work the same? id try it, but mines a 96 N-reg, so i dont have transponder inside the key.
mitch
bstardchild
Moderator
Post by bstardchild »
M1 TCH wrote:just thinking actually.........
mitch
Bloody clever............ Thinking out side the box - does make it a bit easier to steal but everything in life is a risk!!
M1 TCH
Post by M1 TCH »
you could always cut the blade off the key too.......
if your cars got an alarm/immobiliser, it should be ok....
mitch
HGA05
Post by HGA05 »
I only had one key and took it to the local TIMPSONS key cutters and they had to order a blank and they copied the chip and cut key and it works fine. Cost me £30.
Blackone
Post by Blackone »
£30, when where and how!!!! Was it a MKIV key? I need one and i'm getting all sweaty about paying over £100 for a darn key!
HGA05
Post by HGA05 »
Yes £30, have you every heard of a key cutting company called Timpson, dont know if they have one in your area and it works fine in my 1996 Polo SE, It not a genuine VW blank (the blank has HD written on it) and they had to order it in specially but cost £30 inc cutting.
david burton
Post by david burton »
FYI
pre-98 models had no immobiliser. no chip in the key. basically the models with the old style dash.
I'm amazed timpsons could copy and reprogram another transponder in a blank key? a car audio security place might be able to copy the code into a transponder for you. best to ring around.
edit: i see his was a 1996 model - it doesn't have the transponder so the timpsons thing won't work - they didn't have to reprogram anything. unless i am missing something and you managed to get a vw immobiliser fitted by the factory?
but I like mitch's idea the best - stick the top half of the key in your steering column somewhere, then just get another key cut. top notch that man!
Giorgio
Post by Giorgio »
That would mean that there is no immobaliser. This could nulify your insurence.
