Wheel Hub?
Chat about your MKI or MKII Polo (86 and 86F)
Mk2Adam
Wheel Hub?
Post by Mk2Adam »
Does anyone know if the front wheel hub from a Mk3 is a straight swap for a Mk2 hub, just i need a new hub for my mk2 hatch and mr pettsy is breaking a mk3?
Any Advice would be much apreciated.
SpikeyG40
Moderator
Post by SpikeyG40 »
as far as i no they would be the same. but don't take my word for it! i believe they kept the same type of suspension through the mk2 to the mk3, only the g40's and possibly gt's had very slightly different. they had a slightly different top strut mounting.
Hopefully someone will be able to give you a bit more information
Mk2Adam
Post by Mk2Adam »
Cheers Dan :) Can Anyone else confirm please?
SpikeyG40
Moderator
Post by SpikeyG40 »
Dan? Dan i hear you say??? :cry:
sorry wrong brother! i'm Doug! dan is Dan_desiel
regards
DOUG!!!!!!! :wink:
Mk2Adam
Post by Mk2Adam »
:lol: sorry DOUG, just got confused for a minute then, it doesn't take much.
SpikeyG40
Moderator
Post by SpikeyG40 »
no probs mate!
Any luck finding the information you require?
hardhitter
Moderator
Post by hardhitter »
Buy a new one
Mk2Adam
Post by Mk2Adam »
are wheel hubs dodgy from breakers etc then? i got a quote from VAG parts and from the dealers and they were both around £58 and £70, so i hope it's okay to buy a used one. :(
SpikeyG40
Moderator
Post by SpikeyG40 »
the problem with getting stuff from breakers is you can't garantee the thing will be alright! plus if u buy it, and it is damaged, it would be extremly unlikely that the breakers would give you your money back!
also, at least if you buy one from a dealers, you'll have a reciept etc and someone to shout at if it goes wrong! :lol:
Mk2Adam
Post by Mk2Adam »
i got one from GSF in the end, only £25 for brand new, the other new ones i'd seen were £50 minimum. anyway, thanks for the advice Doug
