Reading the forum get the impression it’s a very common fault with polo’s esp on the mark IV. My problem started to happen after the old battery had to be replaced with a new one, as the old battery went flat (but not totally) a few times.
The idling problem occurs only after the engine is warm, not on start-up. Basically the revs drop in a regularish pattern (say every 15-20 sec) but never to the point of stalling (not yet anyway). However it doesn’t suffer the high revving that others have talked about. Also there arent any noticeable flat spots at speed. The problem also comes and goes. But either way its super irritating
Anyway I had the diagnostics done at non official VW specialist who use the bosch system and got the following error codes. ( ive written it exactly as I got it on the printoout)
Control module diagnosis VW AG4 Error memory
0206 throttle valve potentiometer – No Signal
0221 Transmission intervention – open circuit/earth short
No. of errors 2
0214 Power supply signal to low
No. of errors 1
No. of errors 2
I think the ‘0214’ error was cleared, But the throttle valve potentiometer error sounds like it’s the key, can anyone confirm this???
Prior to the diagnostics I tried the battery disconnecting trick for 30min too (well I disconnected the neg only anyway) but that didn’t seem to make any difference. Did I need to disconnect the positive also? Also I understand it could be that the throttle body needs to be replaced/cleaned, or change the Temp Sensor etc???????
The polo is actually my mums car, she’s a newish driver and she’s disabled so she can only use her left foot for the foot controls. So this problem is making it even trickier for her to drive it, especially as she leaves in Drive at traffic lights – the problem is much more noticeable when idling in gear.
Ive booked it into another garage for Monday who want to charge to do the diagnostics again and then what ever else for any extra work!
Thanks in advance
(for info im in the leicester area)
