OK this has recently started happening...on the dash my boot open sign was fading on and off, then totally on then totally off and now it just seems to stay totally on all the time, even though the boot is firmly closed. Also the boot light seems to fade on and off when the boot is open...
also when pressing the button to lock my doors the lights and beep are like 1/4 of the time they used to be, its a really quick flash and beep...
and last but not least my alarm has started going off randomly for no reason on the odd occasion
Strange electrical problem
That sounds like the boot lock has corroded, at least corroded the connections to the boot lock.
This happened to me when I first bought the car, the washer hose leaked water into the inside of the boot door, I had the hose fixed and it was fine for a while. Several weeks later, symptoms similar to yours started to appear and I took it back, they couldn' work out what the problem was, had to take it back about four other times before they finally fixed it and it was only when I mentioned getting out a specialist that they fixed it. During this time they had replaced the boot lock, the lock barrel and cleaned the wiring.
Hope this helps, if it is under warranty get them te dearlership to fix it...
