are they just stick on - or do they leave holes behind on the boot lid?
cheers
GTi badges on the rear
carmadaaron
Randall
A good old hair dryer and some tooth fluss is the way fourth in your removal
and you think im kidding.
Warn up the badge a lil bit with ya hair dryer and get that tooth flush behidn and gently slice it through.
If you find your still got some of the black sticky pad there (you will find you have some there) use sum warm soapy water to clean it up and then a lil bit of polish or t-cut to finalise it
