[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 300bhp 9N3 Polo GTI - UK-POLOS.NET - THE VW Polo Forum
Ok, it might not even be out yet here, but some German tuners have extracted up to 300bhp and 300 lb ft of torque out of it Serious tuning work, and impressive performance, 0-60 in 5.8seconds, top speed of 155mph+.
= Compression ratio 9.5 vs 9.3
= Turbocharger K03-11 vs K04-23
= Engine management ME3.8.3 vs ME7.5
= Exhaust manifold
= Intercooling 1 vs 2
= Cylinder head large ports vs small ports
non-vvt vs vvt
= Exhaust system 54mm vs 63mm
= Injectors 285cc vs 385cc
It is however possible to build the GTI to make similiar horsepower, the following is required :
- Upgrade turbocharger (K04-01 from turboexchange)
- Upgraded ECU software (from you know who )
- Upgraded exhaust system (63mm minimum)
- Upgraded intercooler (front mount)
The above comparison is between the two engines is comparing the 225bhp version against the older non-vvt big valve engine. The new Polo will have the small valve version with vvt and Ko3s turbo which means 220-230bhp just from a remap.
Dangerous Dave wrote:The above comparison is between the two engines is comparing the 225bhp version against the older non-vvt big valve engine. The new Polo will have the small valve version with vvt and Ko3s turbo which means 220-230bhp just from a remap.
Yep, the two engines I quoted were the old 110kW GTI motor vs the 165kW S3/TT engine
I had planned on getting to the dyno just after lunch, but unluckily, my morning filled up pretty quick and ran over till about 3:30...which was a bit late to be driving from the west to KAR.
Saw your post on the VW club forums about the dyno giving the diesels funny results...
