The New Look
Alex_6n2
Post by Alex_6n2 »
My german num plates came through today, and ive got my smooth front end ready so im just awaiting my rear bumper and grille of ebay!
Cant bloody wait :x
Randall
Post by Randall »
your smooth front end - did u buy this or did u do a custom job?
Alex_6n2
Post by Alex_6n2 »
Custom my freind.. check out my post in the club house :)
Randall
Post by Randall »
iNfa-ReD wrote:Custom my freind.. check out my post in the club house :)
What process did u use to fill in the recess?
Alex_6n2
Post by Alex_6n2 »
Just cleaned and sanded it all down, heated some plastic over the major holes and then used p38 to fill it
I used about 4 passes with filler, sanding and spraying after each pass, to get it to where it is now and its still not perfect, I need an orbital sander really but i couldnt be bothered to buy one
I should also have used a mix of fibre glass resin to give it some strength as it will crack if im not careful but its not that important here as when the bumper is fixed on it should be pretty sturdy.
To finish off i just we and dry sanded the whole lot, primered and sanded again ready for paint
polopowah
Location: Hertfordshire Drives: Ford Puma 1.7 Enjoys: Mowing grass
Post by polopowah »
:o respect for being braver than me!
-Ben-
Randall
Post by Randall »
Ok what sort of plastic did u use? where did u buy it from? guess it would be alrite to use a blow torch on or did u use another method
As for the fibre glass factor thats cool - i may give it a go sumtime...me first fibre glass project will be takin place over xmas making up some customer speaker pods on me bro mk2 golf
Alex_6n2
Post by Alex_6n2 »
Just normal plastic that was hanging around in the garage lol, i used a maked flame to heat it just past melting point and stuck it on, then warmed all around it gently till it had a decent seal
Randall
Post by Randall »
just normal plastic hahaha
kk then fair does - i have to see if i can find a cheap bumper somewhere and have a go
Alex_6n2
Post by Alex_6n2 »
Well you can get some special bumper grade stuff but it was £££
Hence it was just normal :lol:
