Hi
I thought this problem had gone but was driving this morning and the car jerked when putting foot on gas. i stopped car and the problem went.
Orignally started when i disconnected the battrey and changed the spark plugs.
has been ok though for at least 2 and half weeks but there is slight hestitation in accelration which is slightly noticeable when putting foot on gas. but then sometimes it doesnt happen car seems lighter when driving when ok.
I have changed the following:
spark plugs
distributor cap
rotor arm
spark leads
Temp sensor
What else can I check?
cheers
Tej
car jerking
david burton
cheers
will run some fuel injector through.
could it be the distributor coil???? this was changed about 3 1/2 years ago!
i changed the distributor cap!
Just to add when i do accelrate it makes like a bump like you have gone over a pothole or something. but quickly accelration on gas misses the bump. Sometimes when trying to accelrate it has no power to shift when stationary have to rev it really high!!!
could it be fuel filter?
cheers
cheers
laura_fairy_22
Car
Try buying some carb cleaner bout £3.00 and take ur air filter off then rev and spray into throttle body for a good ten secs while reving
This stopped my car from stalling when i started it
Worked a treat and for £3.00 garage would of raped me for that lol
worth a try Wesley
worth a try Wesley
another problem arrghhh
Hi
I ran carb cleaner through. When starting car the revs were 2500rpm.
i disconnected the battery for an hour. Put back on but idling between 1800-2100rpm
i drove the car today for around 20 miles locally but revs still high!
is it dangerous to have high revs??
not sure what to do now?
hellp!
also the juddering of the car still happens. I noticed this happens if u keep ure foot on the accerlation for a bit of time and then try to accelrate it starts to bump!!! not sure if the butterfly is a bit funny?
this is driving me mad!
cheers
hellp!
cheers
Sorted but now a minor problem
Hi
I got the machine on a daignostic machine and they recalibrated the throttle body and it is now ok.
i have one other problem when driving and the car is in gear, i take my foot of accelration and at 1800rpm it jerks until it either drops or goes above that
only happens at 1800rpm
what could this be?
what could this be?
