Have you ever found that your windows have lost the one touch function, or maybe you never had it from new?
To enable one touch, do the following:
Press and hold all the buttons down, when they are down, release the buttons and press the buttons 1 time up quickly.
Then hold the buttons so the windows go up again, once they are up, release and quickly press up one time and release again.
*Confirmed correct by Wai_Mak*
9N - Enabling "one touch" windows
- Josh_PoloGTi
- Drives: BMW E85 Z4 3.0i
You're making it so complicated. (No offence) Yes it works, but you don't have to wind the window down all the way. Here's the quick way:
Windows Up? Good!
Note
These buttons have four positsions: Stage 1 up, stage 2 up, Stage 1 down and stage 2 down. This requires you use the 2nd stage on up and down.
This feature is normally disabled when the battery is disconnected.
Windows Up? Good!
- 1.) Press button down for 1 second or less (doesn't matter)
2.) Pull button up until window stops
3.) Pull button up again. If you listen carefully, you'll here a relay click.
Note
