Flip Key
I got one 3 button flipkey and one standard key when i bought my 9N. But the casing of the flip key is completely worn out since i bought the car, as i keep on droping it, and its actually started to break (the plastic that is). The key operates fine, but i wanted to buy a similar key off ebay or something and replace the casing. I modded my old MK4s key and alarm remote and transponder chip to fit into this so im quite familiar with opening it and stuff but never found a transponder chip in this
Second question....
Removing door cards
Front one: ive found a post how to remove it, but i still dont get how to remove the grab handle ive got electric windows, so have the flat handle with the window switches intregated into it. any1 help in this case? i want to upgrade my speakers to components, so i need to remove the door cards i beleive?
Rear ones, i have no clue either? i need to remove the drivers side one to tighten a suspected loose pretentioner
Cheers any help appreciated?
