has any1 had a problem with their driveshaft when they lowered their car?
mine is lowered about 60mm and the drivers side driveshaft is makin a weird grinding noise, or something is? ive just had a new shaft fitted but its still doin it?? can any1 help me??
cheers george
help me...driveshaft
I've lowered mine about 60mm and mine has some sort of knocking noise aswell. At times it doesn't make a noise but then there's times where its really annoying! It sounds like its coming from the drivers side, could this be the same problem. Is there anyway of curing this problem.
My mechanical knowledge is very limited.......could you not but some sort of rubber bushing in the way to combat the knocking problem!
Mat
Mat
hey mate, i know what that is!mine did that loads b4 i raises it a bit, i think its the steering arms hitting the inner body, they didnt make a noise until they wore away the rubber protection stuff and then started hitting the metal!!, easyiest way is to lift ur car a bit, a few mm will make loadsa difference! ( does it over bumps in roads yeh??) also i dnt think u want to put a rubber bump in there cuz it mite affect the arms movement!
my main problem is my drivers side driveshaft? u not had any creaking noises or anythink??
[email protected] if u wana chat bout it!lol
george
george
Prior to having my GTi lowered I had some problems with one of the CV joints on the driveshaft (not the end ones but the one that links the gearbox??). You can tell I'm not mechanical!!
Anyway, I got a knocking and vibration when under heavy acceleration and particularly when turning right. After it dissintegrated twice there have been no more problems (touch wood). Hope its not this but might be worth checking it out!
