is climate control supposed to display the in car temperature?
mine doesnt, was wondering whether it was supposed to??
cheers buds
climate control, in car temp??
ModifiedMadness
- Sponsor
Yeah, thats the whole point of climate control, you set the temperature of the interior temperature that you wish it to remain at and then the climate control takes over and maintains that temperature by blowing warm air when it is cooler than the specified temperature or cool air when it gets too warm...
Or, do you mean the outside temperature as the climate control does have a field for this but this has been deactivated as we have the outside temperature displayed in the digital display in our rev counter...
ModifiedMadness
- Sponsor
I see what you mean now, I have my book infront of me as well.
I don't get the bit where it says about turning it off:
I don't always have mine on, I only use it if I'm cold or the car's misted up.
The entire system can be switched off with button 11. Press and hold until the word "OFF" appears in the display. This function should only be used in isolated cases, e.g. if there is a fault on the system.
ModifiedMadness
- Sponsor
