have had this problem ever since i changed the tank 2 years ago
tried:-
new cap,rotor,plugs etc
seems to only do it when car starts getting warm. when it does it, it nearly puts you through the screen!!
Do the injection units give trouble?
any advice
mk111 1050cc hesitation
Re: mk111 1050cc hesitation
maybe i'm being stupid but did you say what the problem was???mercedesjb wrote:have had this problem ever since i changed the tank 2 years ago
tried:-
any advice
said "hesitation" care to elaborate. and when it gets warm it puts you through the screen? care to elaborate again?
not trying to belittle your question if it came accross that way, just trying to clarify the problem
mercedesjb
mk111 1050cc missfire and jerking
is that a bit better!!
when the car gets warm and you accelerate its as if there is something in the fuel line, and jerks all the time like Kangaroo Juice in the tank!!
It is intermittant however and does feel fuel related.
also just to add, that on tick over the revs rise and fall as if its going onto 3 cylinders, about every 2 seconds-in a regular pattern
anyone had similar symptons?
Tahrey1043
- Location: Birmingham! Enjoys: The pseudo-G-Smiles provided by a 1.6 Megane Sport valver...
As you have had the problem since fitting a new tank it could be the tank breathers. See if it still happens when you havn't got the filler cap on.mercedesjb wrote:have had this problem ever since i changed the tank 2 years ago
tried:-
any advice
