Fitting of parts
alexb
Fitting of parts
Post by alexb »
Hi guys how tough is it to fit the rieger grill onto the polo? Should i employ someone or is it straighforward?
Also Im looking to get the rear roof spoiler (which ill be getting someone to do) how much would this cost to spray and fit????
Finally how hard is it to fit the foglights at the front? With all the GTI mesh???? Should i get someone to do this as well????
Alex
Redline
Sponsor
Drives: BMW 128ti
Post by Redline »
Depends how competent you feel you are at working on a car I guess.
For the grille, I'd be suprised if it didn't just locate into the mounts for the existing one. Howver I've no experience with the Rieger one, so don't quote me on that.
For the rear spoiler, I think I paid about £125 to have the one on my old 1.0E sprayed and fitted. That also included some minor cosmetic work as well.
Foglights, well the wiring loom should be there behind the lower grilles, so it shouldn't be too hard. There's a DIY guide here http://www.tigerstyle.co.uk/poloforum/v ... .php?t=964
polopowah
Location: Hertfordshire Drives: Ford Puma 1.7 Enjoys: Mowing grass
Post by polopowah »
Right
another point of view :lol:
i've had fitted all 3 of what you've mentioned.
Front grille is a simple job, just undo the old one (two funny star shaped bolts, one either side) then line up the new one and use the same bolts
job done 8)
rear spoiler like redline said you're looking at between 100-130 (i paid 110)
and the fog lights aren't too many problems either (all the wiring is there ready to accept them)
:D
-Ben-
alexb
Post by alexb »
How much roughly do you pay for the splitter to be painted????
Alex
inder
Post by inder »
The front gille is not held on by any Torx screws :shock: only four clips :)
polopowah
Post by polopowah »
inder wrote:The front gille is not held on by any Torx screws :shock: only four clips :)
LOL
how in living buggery is my standard grille different
mine was held on by two torx screw either side, the 4 clips merely held it in place!
-Ben-
ModifiedMadness
Sponsor
Post by ModifiedMadness »
Mine was exactly the same, just the 4 clips to get it out.
Demo_202
Post by Demo_202 »
Ive got the same 4 clips... torx screws!? :?
inder
Post by inder »
lol how odd, you must have a 'special' car polopowah :P
polopowah
Post by polopowah »
or i was being a complete roast turnip and mixing the fitting of the 'Aftermarket grille' with the standard one
my bad bruvs
-Ben-
