crankshalf
deathhour
crankshalf
Post by deathhour »
which way does the crankshalf bolt turn to lossen it? anti-clockwise or clockwise. I can't seem to bung it, its bein a bugger
hardhitter
Moderator
Post by hardhitter »
The bolt turns anti-clockwise as you would expect, but it's extremely tight. You need to stop the crank turning by wedging a block of wood against it inside the block. A long breaker bar is also needed.
A new bolt should be used when re-assembling.
deathhour
Post by deathhour »
finally got that bugger to come off, had to use both hands on the rachet to manage to make it move. damn hard work. my cams off now. going to spend the night cleaning it i think
