just fitted my new rear lights and something has gone wrong somewhere in doing it. there RHD light lights so all should be ok, i say should because well interesting things happen.
the light hand side is fine, all works and i spent time getting it nice and flush and looks great, but..... well where to begin.
when i brake my fog light comes on, but when i indicate right its much more intresting. my fog, i think my brake light and my indicator flash (or at least something like that happens)
has this happened o anyone else, i followed all the instructions
mk5 lights
vdubyabush
this is exactly what was wrong with mine, if your old light plugs straight back in and works thats wrong for a start, its not a dodgy light, but it only happened on mine because i didnt do the right hand side light i.e switching wires slicing off lugs and turning switch round, *i think* it may be when you plug the plug in it needs to be back to front.
other than that im stumped
AnT
AnT
polo boi
yea, just switch them around, try an get a light tester an wen u have a cartain light on, it shud light up an u shud then know wot and where 2 wire it, i used 2 fit alot of towbars 2 fords an was doing alot of wiring up wen i work 4 ford but the main thing is 2 try an get the light tester if u havnt got 1 already
