MkIII Thermostat
skypilot30
MkIII Thermostat
My temperature guage sits permamnently at about 70 when the engine is warmed up, is this normal. I understand the thermostat should start to open about 83 and be fully open at 113.
Is the temp normal, is there something wrong, I thought normal guage temp was around 90. Do I need to replasce my thermostat or is some thing else wrong ?
hardhitter
- Moderator
Tahrey1043
- Location: Birmingham! Enjoys: The pseudo-G-Smiles provided by a 1.6 Megane Sport valver...
yeah, and get on it quick. I drove round like this for best part of two years thinking "this car's really great, it's always so cool, it'll never overheat" til I found out overcooling WASNT a good thing and was probably causing engine damage.
my thermostat was all gunked to hell
but I changed the temp sensor as well just in case (because that was gunky too). You may as well do the coolant at the same time as it may well have sludgy contaminants in it now from that effect, and you'll have to drain some of it off to avoid a massive mess when swapping components anyhow.
hardhitter
- Moderator
Tahrey1043
hardhitter
- Moderator
Tahrey1043
Whoops.... well, too late nowhardhitter wrote:No, GSF ones are not as good quality. They work at a different temperature to the genuine ones, not something I recommend.
(did seem to lose some coolant the one time i gave it a purposeful engine heating test?)
tupac2makaveli71
