LAWB and JAKETHESNAKE are u listening?
chubbster
Post by chubbster »
@lawb, im interested in how your lowering attempts went. im considering going for the eibach 50mm drop springs. what did you use? are you happy with it?
@jakethesnake, i notice youve got the eibach springs, pro kit right?, did u get the springs before your g-max shocks? if you did how did it handle and ride? i cant afford the shocks right now but there coming soon
anything that could help me would be great, cheers :D
jakethesnake
Post by jakethesnake »
Hi chubbster
Yes I do indeed have the Pro Kit Eibach springs with 30mm drop. The Sportline springs have 50mm drop. I don't think the Sportline were available when I bought mine, if so I may have been tempted by the lower drop although I think they will have an even firmer ride.
When I first fitted the springs I used the standard dampers but these were 40K+ miles and basically worn out so the ride was poor. I ran it like this for about 2 months and then stripped it off and refitted with the new Gmax dampers which was an improvement, although still quite a firm ride it's a lot less bouncy :lol: .
The Eibach Pro Kit springs are designed to be used with standard dampers. The Sportline are definatey not because with a 50mm drop you need uprated and importantly 'shortened travel' dampers.
I would not advise using your standard dampers unless you are certain they are in good condition because you're just wasting your time as you will have to strip it off again and re-do the job to fit new dampers.
You would be best waiting a bit longer until you can afford new dampers and doing the job properly 'once'.
Don't forget you will need an alignment check afterwards to set up your tracking/camber which will cost approx £40-£50 otherwise the handling will be dodgy and you will wear out your tyres very quickly.
How old are your dampers and what mileage have they done ?.
I would also consider fitting new top mounts at the front when you have it apart. They don't cost much at all.
Hope this helps you out. Please ask more questions if I haven't answered all your thoughts.
chris
chubbster
Post by chubbster »
the cars done 30k and i guess the dampers have never been changed.
ive had the car for a month now and as youve said before its starting to look ermmm.....a touch high. im after a cheap option to do me for about 9 months then id upgrade the shocks. id looked at the koni and bilstein full kits (dampers and springs) and at around 400 quid its abit steep. ive also looked at the spax and gmax kits but i dont really trust them much, but for 250 its looking better and better. also theres the problem of the cost of fitment....
not to sure what to do right now because im off to the isle of man for a year and cash is going to be REAL short.
chubbster
Post by chubbster »
oh yeah i forgot to say thanks :oops:
cheers :D
Nick
Post by Nick »
Go on......be tempted with the Sportline.......then you'd have a set of Pro Kit springs going spare :lol:
Nick.
jakethesnake
I don't think I'll be changing for a while. I want some new wheels first.
If I do change the springs you're welcome to them :wink:
@chubbster, the weitec kits look good quality and value for money. They do one for about £250.
If you're going to IOM for year you have to get your suspension sorted :D .
chubbster
Post by chubbster »
this will be my last post here in england. i go tomorrow. i cant wait to sample the roads!!! :D
KarlM
Post by KarlM »
happy travels mate 8)
jakethesnake
Good luck with whatever you're doing on the IOM.
Let us know if you get your suspension sorted 8)
chris.
chubbster
Post by chubbster »
sorry ive been ages replying. ive been setting up house in the IOM. wot a great place. the roads are fantastic! all the main roads are basically really twisting harsh lanes. fantastic!
oh yeah im in my 3rd year of study at liverpool uni doing marine biology. so the last year is out here. and thanks for the wishes of luck. it sounds like i'll need it. its the second week here and weve already got a 1000 word scientific essay to be handed in, in 3 days!
