Steering wheel
Steering wheel
re:eh?
presumably u have to un-hook the battery to stop the air bag from setting off while u are takin the wheel off. If u disconnect the airbag the air-bag warning light will be on all the time & the ECU will be reading a fault code. how can u fool it into thinking theres no problems?? I'm sure iv seen this sumwhere but cant remember.
Hayesay is right, the car will think there's something wrong with the airbag. If you don't know what you're doing, don't do it. The airbag is highly explosive and that makes it a dangerous bit of kit.
Leave it alone, or take it a mechanic that knows...
On topic: if you mount a non-airbag wheel (really can't see why) you'll have to plug a resistor into the empty airbag plug. I don't know any more than that. I replaced my steering wheel, but I kept the original airbag in the process.
Any switch you encounter will definitely not be to trigger the airbag to go off. Oh, and don't mess with the connector spring, mounted on the rear of the steering wheel.
Re: wheel
Yeah it does look the same, but it's about twice as thick and softer too. The surround is shaped to suit the 'correct' grip (i.e. 10:15) with cutouts for the thumbs.hayesey wrote:bit hard to tell wot its like in that picture. jus looks the same as the normal one. sounds quite nice tho. how much they sell for??
The size is exactly the same as the original is, since it uses the original wheel as a base, allowing me to keep the airbag.
They retail at around 270€ and can be found here:
http://www.raid-rdi.com/d/fs_raid-rdi_d ... ign_vw.htm
Didn't pay that much for mine though, got it off eBay.
