Black Plastic Car key
Reeyad
Post by Reeyad »
Hey anyone knows what the black plastic is that comes with the car, is it just a simple template, or can it actualy open the door. Just found it in the VW holder thing.
To cold to go outside......
Silky V
Post by Silky V »
Isn't it incase of breakdown? I think you can use it to start the car.
Can anyone clarify this?
inder
Post by inder »
The little key, which I think you on about, is the 'emergency key' and is meant to be used if you loose the main key.
Works with all locks and will start the car, for temp use only though
Mine did not come with one, nor come with the keycode tag or a spare key :( had to order a spare main key :roll:
benny oopz
Post by benny oopz »
I think it's the valet key. You can leave it with garages for services or valet parkers.
I think it limits the time you have to start engine after opening the car with it. Also I don't think you can unlock the glove box with it.
Not 100% on this. Give it a try.
andyg
Post by andyg »
I'm pretty sure the little plastic key doesn't start the car but does open the locks.
hot_polo
Post by hot_polo »
i think the key has got the immobiliser number printed on it, so you take it to vw if you loose your original key, so that they can charge you a bomb for a new one :evil:
inder
Post by inder »
I recon your talking about key B in the picture Reeyad :wink:
see description for full info, 'emergency key' as I thought :)
omicron
Post by omicron »
As said mit's a spare for when s**t happens. Don't count on it as a long term solution as it will fall apart.
Reeyad
Post by Reeyad »
inder wrote:I recon your talking about key B in the picture Reeyad :wink:
Yep thats the one.....
inder
Post by inder »
Shame mine is missing that key :( would be useful to own
ModifiedMadness
Sponsor
Post by ModifiedMadness »
Mine is as well, and the radio code.
Not that I'll need it, but would be nice to have.
nickpolo
Post by nickpolo »
if i've got key tag c, can i order an emergency key B from vw?
toXXin
Moderator
Post by toXXin »
Yes, thats got your key number on it.
They'll still need to see your V5 and ID, and they'll still need the car to program it into the ECU.
inder
Post by inder »
You can still order a new key without having the keycode thing thru the dealer, they would require your car's chassis number to do this
(I've done this with success)
toXXin
Moderator
Post by toXXin »
Yep, that is also true! :)
