Titch's newest problem - door handle
titch
Post by titch »
ok the door handle thing to open my passender side door from inside is very very slack and just about opens it and no more, is there any way i can fix this? :( i dont like seeing my polo unwell
yumzone
Cant help but ...
Post by yumzone »
... I have the same problem on both my doors plus they squeak a bit when pulling to open
titch
Post by titch »
so does no 1 know how to fix it as its annoying :(
Si_GTi
Moderator
Post by Si_GTi »
Mine squeak too a bit on use. The door pull is connected to a cable which hooks onto the door mechanism. To investigate the slackness, strip the door down by removing the door card and and sound deadening, then inspect the door pull and cable to see if it's broken or misshaped in some way :?
To remove the door trim:
1. Remove screw from doorcard - its nearest the door shut at the front of the door, can't miss it.
2. Prise the plastic insert in the door handle off (it sits just behind the door pull there) to reveal two more screws. They're quite deep-set so you might need a longer screwdriver to remove them.
3. Remove the door card.
4. Remove the sound deadening. IIRC I nearly lost a couple of the clips that hold the material in place so watch out :wink:
To replace the door trim follow those four steps in reverse!
I'm going to be changing my own door pulls in a couple of weeks time so will do a DIY guide with photos then :D
titch
Post by titch »
thanks si ill go give it a wee go the now(although its probably not best to do it in the dark :lol:
titch
Post by titch »
ok i took out first screw but now im lost :lol: you'll need to break it down a bit more as i dont know a lot :lol:
titch
Post by titch »
ok i prized sommit off near the door pull and i think i broke it but it didnt reveal any screws :lol:
titch
Post by titch »
and whats "sound deadening"
dino
Sponsor
Post by dino »
titch wrote:and whats "sound deadening"
Answer is in the question really - Sound deadening kills sound ie road noise.
Si_GTi
Moderator
Post by Si_GTi »
Hmmm I will have to find some pics for this then :) I lost all mine when my computer went up the spout at the weekend and I reformatted the disc!
titch
Post by titch »
ok so what does "sound deadening" look like :lol:
yeh si i think you may need pics also :lol:
inder
Post by inder »
its the black foamy stuff behind the door card :P
I think there is some picture thread about removing a doorcard on this forum... not sure? hopefully you will find it
easy once you have done it the first time :D
