wheel spacers
Ant_6n
wheel spacers
Post by Ant_6n »
im thinking of putting wheel spacers on my car would i be able to just fit them on the back or would i need them on the front too, any thing special needed? thinking of something like this http://cgi.ebay.co.uk/4-Hole-Wheel-Spac ... dZViewItem
is this an ok size?
cheers Ant
DScape
Post by DScape »
I got mine from the site below, with longer wheel bolts as well. Think I bought 5mm just for the rear, and none on the front. Dunno if that's alright, but it has been for the past7 months
http://www.performancefx.net/wsvw.htm
That ebay link is £4.99 per spacer, if you get 2 plus postage works out to about £13, which is cheaper then the site I've just told you about.
Depening on what size you go for, you might want to think about longer wheel bolts.
Ant_6n
Post by Ant_6n »
what size bolts did you get? i was only thinking of about 5mm-10mm
the type 13 on that website says Type 13 - These universal spacers are fitted between the hub and the wheel using the original nuts or bolts
so can i just use the normal bolts i already have?
which ones did you get?type 11 or 13 and how much is your car lowered as im thinking of getting mine lowered but dont want it to rub?
sorry for all the q's
cheers Ant
DScape
Post by DScape »
Ant_6n wrote:what size bolts did you get? i was only thinking of about 5mm-10mm
cheers Ant
Yup that's right. The type 13s you can use your original bolts, but obviously at your own risk. I'm not 100% sure if there's a great risk of using spacers with standard bolts, but I didnt want to find out.
I bought the type 12's. which come with longer wheel bolts and are car specific, not universal. They were the 5mm ones and the bolts are slightly longer then your standard ones.
Mine's on coilovers and lowered at a guess around 60-70. Mine rubs on the back quite a bit and I think its because I have spacers, but without the spacers I can't have any centre caps on. All depends on what wheels you have :)
Ant_6n
Post by Ant_6n »
have you got any pics of the rear wheels do they stick out alot?
cheers Ant
polo boi
Post by polo boi »
would there not be a high risk off the wheel comin off, if u use standard bolts with spacers? as the bolt length is bein shortend bcoz of the spacer?
Ant_6n
Post by Ant_6n »
yeah thats why im gonna buy longer bolts, better safe than sorry
polo69
Post by polo69 »
Can you put these on any wheels?
Ant_6n
Post by Ant_6n »
i would think so depending on the et of the wheel if its lower they stick out already or something like that. but im gonna buy some then put them on the bbs im hopefully gonna buy.
