First off, could a MOD make this a Sticky please - Thanks
I did a quick search and couldn't find anything about this so I though I'd start a topic on it.
I thought it would be useful to have topic stating the paint codes of the different colours incase anyone ever needs to know them and to save them having to look in the boot.
I've started it, please add your's if you know it.
1) Reflex Silver - LA7W
Paint Codes
ModifiedMadness
- Sponsor
Paint Codes
Last edited by ModifiedMadness on Sat Apr 08, 2006 6:42 pm, edited 1 time in total.
Re: Paint Codes
1st off didnt know about relfex silver is that a new colourModifiedMadness wrote: I've started it, please add your's if you know it.
1) Relfex Silver - LA7W
mine is
2) Candy White - LB9A
ModifiedMadness
- Sponsor
Re: Paint Codes
Weedle wrote:1st off didnt know about relfex silver is that a new colourModifiedMadness wrote: I've started it, please add your's if you know it.
1) Relfex Silver - LA7W![]()
mine is
mysteryboy
Have you jokers not been to the diy thread
http://www.tigerstyle.co.uk/poloforum/v ... php?t=4712
dont know how usefull it is tho
ModifiedMadness
- Sponsor
i agree there are just to many random posts with the words "paint" "Codes" in so it brings them all up - and i dunno about you guys but i DO NOT have the patience to trawl through them !!ModifiedMadness wrote:I typed in Paint Codes in a search and it came up with loads of useless ones, why the hell does it not bring that one up first![]()
Cheers for that though Mysteryboy
If you are getting too many results in your searches, try using the "and" command. For example typing into the search box, paint and codes will only return posts with the two words in. Just using paint codes as a search tearm brings back every post with either paint or codes in it and you get a massive number of posts in the search result which have no relevance to the subject you want to search for!
Use the paint and codes search and the stickied topic linked above is no. 8 on the list and you'd have had no problem at all finding it
