strange knocking??
danny_boy
strange knocking??
Post by danny_boy »
hello people i was wondering if you could help.
sometimes when im slowing down an and get 2 low speed ther is a sorta knocking noise coming from the front wheel area. this doesnt happen very often, ive noticed it about 3 times altogether.
but the wheels balencing is out so i thought it mite be somthing to do with this?
cheers Dan
tupac2makaveli71
Post by tupac2makaveli71 »
could be your bearings need replacing or regreasing....
taylor
RE: Knocking
Post by taylor »
I have had a few noises like this, mine was the pedal box which shakes under the foot but also made a noise which sounded like it was from front wheel? no idea why and the other was the cat had become lose from rubber straps.
May be worth a check at least.
JWC
Post by JWC »
Sometimes the brake shoes move about and make a sound that doesn't sound like you'd think it would, if you just cover the brake, see if it goes away. My Moms car does this a lot. The shock absorbers also knock when they are knackered, and this would when you select a lower gear, loading up the front suspension.
