40mm lower :)
danny_boy
40mm lower :)
Post by danny_boy »
ive just had my car lowered 40mm yesterday but looking round the car 2day ive found that the rear drivers side is about 2cm lower than the pasenger side :shock: why is this!!!
the passenger side doesnt look like its been lowered at all :cry:
please help
olop_chris
Sponsor
Post by olop_chris »
hmm sounds abit strange, either somethings wrong or the suspension just needs time to settle in
DanDiesel
Sponsor
Post by DanDiesel »
CymruPolo wrote:Were you parked on even/level ground when looking?
was just thinking that??
titch
Post by titch »
russ swift had the same problem in his mini not that long ago, he couldnt work out why the passenger side was higher than the drivers side
:lol: :lol:
mysteryboy
Post by mysteryboy »
I had a similar problem. My front left was over 1cm higher... now its gonne down a little but is still a little higher...
kipper
Post by kipper »
i know how u feel, mine does it to. at first when i lowered it i realised the springs wernt in the correct place but they sorted themselves out then, even now if i look at it, it sometimes looks like one side is higher then the other. might have something to do with weight siptribution in the engine or something. personally i wouldnt worry about it. might be the ground or springs not in place properly. it might sort itself out........... if not then.............. dunno!!!
polo power
Post by polo power »
are you sure the spacers and shims are the right way up? this could cause that to happen, another one is that there is a little clip halfway down your damper, if you are missing that this could also affect it. hope this helps.
