Superb guide mate, very helpful
. I need to remove my bumper and my bodyshop wants £60 to do this saying its a 3 hour job
From this it looks quite easy to me. Is it also easy to put back on. If so i'll give it a go myself tommorow (edit: today) and save some money
But when fitting back, does it simply slide back and screw how it was removed? I mean like it doesnt need to be re-aligned or anything should it. It should just fit back one way that puts it back to how it was before removing right?
Another thing is the airbag sensor disconnection. Does this in anyway affect the airbag system, i.e. flashing airbag light that needs 2 be reset, and did you remove the negative pole of battery, or did u just d/c it regardless but with engine off (obviously
