Door Mirrirs work in unison !??
When I move the little switch / knob both mirrors move , should they do this ? they never used to , ,
Ross Clarke
All as stated , thankyou, someone had knocked the o/s mirror dislodging the the outer cover so I thought a problem had been introduced. still i took the chance to oil the spring pivot before replacing the cover so now i can push it out of the way, if i remember .Ross Clarke wrote:Yep should do that, its in the manual.
Its so if you have a second driver (a partner maybe) and they are a bit shorter/taller they can adjus the seat, then move both mirrors in/out at the same time as they move in opposite directions.
