titch
Posts: 217 Joined: Wed Feb 08, 2006 12:18 pm
Post
by titch » Mon Jul 03, 2006 8:58 pm
how do you do it?
my passenger side door doesnt open from inside now so need to get the door card off to try and fix it, but how do i go about getting it off?
thanks
MaxZ
Posts: 1472 Joined: Mon Apr 10, 2006 10:20 am
Post
by MaxZ » Mon Jul 03, 2006 9:12 pm
you wont believe how many times this has been posted!
undo the screw next to tweeeter,
take out the door pin by unscrewing it..
take out the door handle and you;ll find 2 more screws
after that go round the card with a screwdriver carefully unclipping the clips around the door card and it should come off after that
titch
Post
by titch » Mon Jul 03, 2006 10:08 pm
yeh ive posted this before but i didnt understand it the last time, and dont really understand it now either
tweeter?
titch
Post
by titch » Mon Jul 03, 2006 10:28 pm
right got it off, im guessing you jus peel the foam stuff off now
MaxZ
Post
by MaxZ » Mon Jul 03, 2006 10:34 pm
for the tweeter there's another screw you undo that and it comes out.. make sure you unplug it.. then u can just force the tweeter out.. most of the aftermarket tweeters go in with a very tight fit so no need for glue
titch
Post
by titch » Mon Jul 03, 2006 10:35 pm
anyway i got the door card off, and now the handle can move further back it can open the door
Del_GTi
Posts: 694 Joined: Wed Apr 21, 2004 1:32 pm
Post
by Del_GTi » Mon Jul 03, 2006 10:53 pm
Sounds like a connecting rod has been bent if the handle needs 2 be pulled right back to open the door.
titch
Post
by titch » Mon Jul 03, 2006 11:19 pm
Del_GTi wrote: Sounds like a connecting rod has been bent if the handle needs 2 be pulled right back to open the door.
and whats a connecting rod?
Del_GTi
Post
by Del_GTi » Mon Jul 03, 2006 11:26 pm
It's a rod which connects the door handle to the latch/lock mechanism inside the door.
