Interior Lighting
samil87
Interior Lighting
Post by samil87 »
does anyone know wher i can get the bulb that goes behind the heater switches for the 6N2?
i tried pushing then twisting ithe middle switch and then pulling it out but it wouldn't budge
suggestions?
inder
Post by inder »
you can get the replacement bulb from vw parts or maplin electrics shop might carry it or maybe even halfords at a push. its a very tiny bulb
I have the vw part number if you need it
to make it easier to remove the middle knob, first pull out the coin tray above the controls, then take off the black surround on the control unit and now you should have more to grip the middle knob to pull if off in one sharp move
getting the bulb out can be hard, I used a pair of long nose pliers, being careful not to crush the glass of the bulb. could also try a small piece of tubing
Hope helps
samil87
Post by samil87 »
how do you remove the middle knob?
i tried pulling it but it wont budge
inder
Post by inder »
I just posted above, how to get more access to pull if off :?
It will come off, just pull harder hehe
samil87
Post by samil87 »
taking for ever to try and get the bulb out do you have unscrew it or jus pull it out?
inder
Post by inder »
It just pulls out, use a long nose set of pilers and carefully grip it and pull it towards you
samil87
Post by samil87 »
thanx 4 the tips mate will giv it another go
samil87
Post by samil87 »
mate lent me a pair of long nose pliers. pulld the bulb str8 out without a problem. went 2 my local auto spare shop and he gave me a replacement...95p
thanx for the help
inder
Post by inder »
nice one, glad you got it sorted now
looks good lit up again 8)
samil87
Post by samil87 »
yes it does
will c clearly 2nite
