Key code?
mmh
Key code?
Post by mmh »
Hi does anyone know if the code number for Mk4 keys is located anywhere on the car pehaps the door lock barrels?
I bought my Polo secondhand and was missing the black plastic temp key and the tag containing the key codes.
Cheers,
Mo
Stacey_K
Post by Stacey_K »
Not sure what the temp key is?? But if ur looking to have a spare cut most places do them. We had a spare cut in cardiff with immobiliser code for around £20, vw wanted alot more!!
mmh
Post by mmh »
Stacey_K wrote:Not sure what the temp key is?? But if ur looking to have a spare cut most places do them. We had a spare cut in cardiff with immobiliser code for around £20, vw wanted alot more!!
The temp key is a black all plastic key that is for temporary use.
From new there should be:
2 x keys with immobiliser chips inside
1 x Black plastic temporary key
1 x Keycode tag with the key no. for the keys and immobiliser code
£20 for a cut and coded key! :shock: that's the bargain of the century. I've been quoted shed loads for that in the hundreds.
Mo
Polo Paul
Post by Polo Paul »
If you havent got the code go down to a VW main agent armed with proof of ownership etc and they should be able to look the code up on the computer. They may or may not charge you for this.
