http://www.ultraleds.co.uk/
yeah, they fitted fine apart from the little wedge bits which stick out the side, where you twist it and it screws it tight, all i did was just used some plastic cutters to make them just slightly shorter and they're perfect.Gareth_GT_Hatch wrote:I dont think you can buy mk2 ones off ultra. I looked myself. I've ended up doing what I did on the mk3 in the end. Replacing the two bulbs in the top with a strip of 12 LEDs. Now all I need is an LED in the right fitment for the clock.
Adam, those are mk3 ones. I'm suprised you got em to fit.
