whats this air part
Chat about your MKI or MKII Polo (86 and 86F)
sparky93
whats this air part
Post by sparky93 »
I have some sensor on my mk2 breadvan. What is it and whats its purpose.
It is a small black relay sized box screwed to the upper bulkhead.
It has a 2way cable going to it, and under the connecter there is a covered up air connector.
On oposite side to that, there is 2 air pip connectors, one with a grren marker and the other with a pink marker.
a black pipe from somewhere(hidden by airfilterbox) goes into the pink, and a green pipe from inlet manifold goes to the green maked point.
It was hissing all the time, i swapped the 2 pipes round so it was green to green and no more hiss.
the connecter that is covered up has a slight suck when uncovered. Both pipes suck also.
Engine does hunt a little when warm.
polokris
Post by polokris »
i only have the green in mine... does hiss a little... cant remember what its for... lol... but i know my weber (standard) carb runs well with out the pipes.
