Ok so i got my bulbs today, another problem has just cropped up tho,
The following is a quick diagram of my problem:
As you can see my old bulb has parallel fittings on both sides of it (hence the black dots in case you were wondering lol)
Now with the new bulb, they are offset slightly, i tried both halfords and maplin for an amber bulb with parallel fittings, but with no luck at all,had to settle for ambers with offset fittings, only a couple of £.
However when i recieved my clear front indicators, i got a new bulb mount that worked perfectly with the new offset bulbs i bought. Trouble is the bulb mount is a totally different shape to the connecting block on my polo.
The one on the polo already has rounded edges (top), whereas the new block is rectanglular in shape(bottom)...no way of connecting
Hopefully i can cut off the old connecting block on my polo and replace it with a more modern connection that will fit nicely into my rectangle shaped connector, looks like the only solution unless there is another way of doing this?
