I'm thinking of tinting my windows but first I'd like to know afew things, also note that Im not willing to pay someone £130 to do it just to pay £120 for labor...
The radiator strips at the back, do I put the film over that? if so will it be damaged or have a high risk of being damaged if I ever have to take the tints off?
Is the film easy to remove?
And does it lower your insurance, increase it, or doesnt affect it?
The dangers of tinting?
Dirty Engineer
When i brought my MK2 it had a self tinting job done on the rear window over the window heating stripes, it had been there for about 4 years and i pealed it off without any problems at all.
Also, i must tell you that having tried tinting myself, i would spend the £130 for it to be done professionally.
The problem you face is that you will almost certainly leave kreses in the tinting because its so sensitive and very difficult to apply properly.
Also, you face the problem that unless you peel it off whilst its still slightly sticky (the tint), when you peel it off you will have to pull it off with a heat gun or hair drier to make sure you dont leave bits of tint on your window, this usually requires you taking the window out.
Spend the money.. unless your wanting a rat look, ie a look that makes your window look like its cracked.
ZOMBIE
heater strips will be fine
as long as you cut the tints to size before hand, by good quality tint and use lots of water in a squirty spray bottle with a little soap and take your time you will be fine. Polo kris has done his and they look pukka- ask him for tips. i did the windows in my mk3 golf- tip for the back is to do it in 3 parts lining the edges up with the heater lines
true, and thanks tom my man!!ZOMBIE wrote:heater strips will be fine
its not as bad as ppl think... patients is all u need, and u need to be handy!!
its got instructions.... if u fluck it up.... if u got the money, peel it off and try again... and when u matered it... u can do ur mates cars!
tupac2makaveli71
