I have recently purchased a B reg Coupe S. The only niggle I have found with it is that sometimes i cant select first gear. I have to put it into second, then try and slide it up into first without going into reverse.
Can anyone suggest how i can fix this as it is becoming a real problem on hill starts!!!
AJ
Gearbox Problems
if u can slide it straight into reverse sounds like the linckage may be needing a change! or something along those lines, its the bit that means u have to push down on the gear lever and then push it across into reverse! they are easy to replace and may stop the problem with first gear. my old mk2 had the same problem when i first got it and that was one of the first things we did!
Nelson_Wilbury
- Moderator
madmatt
- Moderator
this will sort it
its your gate miss aligned needs adjusting
not to hard to sort out
