Can anybody help?
Tommyl
Can anybody help?
Post by Tommyl »
1. I have bought some new sidlight bulbs abd i dont no how to change them. Do they just pull out or is it a twist and pull or sumthing?
2. When i replaced the casset player with my headunit the head unit always stays on even after you have removed the key but the original vw player turned off once the key was removed?
3. The contol to put the passenger side window down on the drivers side dosnt work i can put it up but not down?
carmadaaron
Post by carmadaaron »
i can help you with the 2nd one.
you need an ISO connector from halfords to connect the car's harness to your aftermarket head unit.
Si_GTi
Moderator
Post by Si_GTi »
And I can help with the third one, it sounds like the switch is knackered on your driver's side? If you operate the passenger side window using the switch on that side, I'm guessing it works perfectly :)
The switch isn't very expensive to replace but usually requires removing the door card to fit it (although some say you can replace it without stripping the door down).
loud
Location: 25 miles south of Aberdeen Drives: 9N3 Polo GTi
Post by loud »
and i can help u with the first one, they just pull out
Tommyl
Post by Tommyl »
Cheers guys
