I was wondering if anyone knows if the 6n2 rear lights will fit straight on to the 6n without any mods??
also whats the best way to remove the side strips off the car?
6n2 rear lights on a 6n???
i have the al red 6n2 lights on my 6n, the can go straight on with no mods but will stick out a fair bit, i drilled a bigger hole into the inside hole of each light, ie both the ones nearest to the bootlid, and then i saded a lil 1mm deep by 2mm high square out of the bottom corner of the right hand light, and sanded the top of the left lights, and now they barley sit out at all! depends how flush u want 2 get them mate
Jamie-RIL3124
Bumper Strips
Use a heat gun and brake fluid that should do the job but watch you dnt take off the paint.
Jamie
Jamie
Jamie-RIL3124
Bumper Strips
Jamie
Jamie
Jamie-RIL3124
Bumper Strips
Jamie
Jamie
