not starting?
M7
not starting?
Post by M7 »
my 1.2 wouldnt start when i got up this morning. it is just spinning over and not firing
anyone ever had this problem before or know how to sort it?
AKs_SlickPolo
Post by AKs_SlickPolo »
Could be a immobiliser issue. Have you tried starting it with your spare key?
M7
Post by M7 »
checked the plugs and capacitors and theyre all fine.
plugs are sparking when theyre in the capacitors too
petrol is not going in at the correct pressure so were thinking the fuel pump or the relay?
its just a right pain in the arse as we dont have a proper diagnostic machine :evil:
anyone had a similar problem in the past?
M7
Post by M7 »
turned out to the the somthing to do with the cams.
the chain had slipped :? gunna cost a fortune to fix :(
carmadaaron
Post by carmadaaron »
time for a 1.8T solution :idea:
M7
Post by M7 »
cant afford the 1.8 for a while. another few years of study to come
but vw are fixing the problem no questions asked! apparently they have given an extra year on the warrently for this fault.
the timing chain has slipped i think
