[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 GTI Alarm and Central Locking Issues!! - UK-POLOS.NET - THE VW Polo Forum
Has anyone had problems with their central locking not working from their key fobs? Both my key fobs are failing to lock / unlock my doors through central locking.
It also appears my alarm is not being initiated as I'm unable to use the key fobs.
As a though are your windows working OK?. I've recently had problems with my drivers side switch (water) and it totally goosed the central locking and alarm. One new switch later and all is as it should be
I have the same problem mith my lupo gti, inside the fob the piece of metal that should touch the battery to make a connection comes loose, just bend it back toward the battery and it works a treat!
