has died... help?
just stopped working all of a sudden
Central locking
Petrol_Head
hey,
have you changed your rear-lights?
I changed my rear lights and had the same problem. What happened was the central locking pump is located at the rear of your car. Water leaked threw the rear lights and buggered up the electriconics in the pump. (It happened to me because the bolts werent tight enough plus i should have used a sealant.)
What you should do is open your boot, then where the first aid kit is, take the kit out and then hidden in foam their should be a black box. That is your central locking pump. Check to see if any water damage or anything?
Otherwise i dont know??
Does anybody know how big a job it is to transfer central locking from a CL to an L? My friend is breaking a CL and has the fobs and i was thinking about taking the central locking. From what i gather i would need to take the motors / rods from behind the door cards, the loom and that thing from the boot lol. Can anybody help?
Cheers Gav
Cheers Gav
