WIRING A SUB
Discuss In Car Entertainment
jason11
WIRING A SUB
Post by jason11 »
wats the best way of wiring a sub up in a mark 4 polo ??
HELP :)
willriseley
Post by willriseley »
RIGHT!
nice big power cable from the battery with a fuse down the passenger side of the car to the boot.
rca leads down the drivers side and into the boot
remote lead down the middle and into the boot
if you keep the leads apart it helps to stop the inteference
a decent size earth lead from the boot floor or sumwhere there
tuck the wires away so you cant see them and there you go
try and keep the power,rca and remote leads away from each other as much as possible to avoid poor signal
ModifiedMadness
Sponsor
Post by ModifiedMadness »
You can run the RCA's and Remote together if you like, some RCA's come with a cable inbetween them that can be used as a remote :D
I should imagine a 4guage kit would do the job.
bobtknob
Sponsor
Post by bobtknob »
when wiring in the power cale did you guys go through the bulkhead or what?
polo power
Post by polo power »
yes there are a few rubber gromits in the bulkhead, which you van run your cable through.
samil87
Post by samil87 »
where wud u suggest the best place to ground the amp?
paulzpolo
Post by paulzpolo »
willriseley, u wont notice any interference,if u run the cables rca and remote,
only if your after a high sound qualitiy,but nothing you will notice....
