How do i change the bottom middle grille to a 6n2 GTi one?
kipper
Post by kipper »
hang on a min......... y u ripping ur grills of?........... y dont u just gey a flat headed screwdriver and run it round the edge of the grill till u find a clip then use the screwdriver to push the clip out or the grill down watever. thats how i managed to get my grill bit of........ although i did pull it to start with thus breaking a clip but then decided it would be wiser and smarter to use a flat screwdriver.
way_z
Drives: 6n2 1.4 TDI
Post by way_z »
to get the lower middle grill out without breaking any of the clips, all i did was look behind the bumper to see where the clips were and then using a flathead screwdriver carefully wedged it in from the front at where each clip was and popped them out one by one tilting the screwdriver out like how u would use a crowbar to wedge something open.. the bumper is abit flexible so it flexed enough to realease the clips this way. by the way is it the xenon lights you bought cuz thats a bloody good price for them, i'm assuming they're brand new?
alexperkins
Site Admin
Post by alexperkins »
way_z wrote:to get the lower middle grill out without breaking any of the clips, all i did was look behind the bumper to see where the clips were and then using a flathead screwdriver carefully wedged it in from the front at where each clip was and popped them out one by one tilting the screwdriver out like how u would use a crowbar to wedge something open.. the bumper is abit flexible so it flexed enough to realease the clips this way. by the way is it the xenon lights you bought cuz thats a bloody good price for them, i'm assuming they're brand new?
How do you look down behind the bumper without taking it off - surely thats impossible :P
Ive bought xenon bulbs not the xenon HID, but in the heads and fogs theres H1, H7s and W5W Phillips blue vision bulbs (which are xenon filled)- all came to around 50 quid for the bulbs, but it looks sweet as. Xenon HID is a project i might look at, but its like 200 to 300 quid for the unit (a tad out of my price range at this point in time)
Cheers,
Alex
way_z
Drives: 6n2 1.4 TDI
Post by way_z »
oh yea i remember now... i managed to look behind the bumper cuz i was fitting the GTi lower lip at the same time, once u take the lower lip off its easy but fitting the GTi lip back on was a mission! once u manage to put one side in the other side pops out!? are you gonna fit the the GTi lower lip/splitter?
alexperkins
Site Admin
way_z wrote:oh yea i remember now... i managed to look behind the bumper cuz i was fitting the GTi lower lip at the same time, once u take the lower lip off its easy but fitting the GTi lip back on was a mission! once u manage to put one side in the other side pops out!? are you gonna fit the the GTi lower lip/splitter?
You got me there :P Whats the lowerlip/splitter? I'm sure i read this somewhere else but i can't for the life of me remember what it said!
Alex
way_z
Drives: 6n2 1.4 TDI
Post by way_z »
its the black plastic bit at the bottom that goes all the way across and underneath your bumper, mine was like yours but I swapped it for the GTi one... definitely recommended mod! 8)
alexperkins
Site Admin
way_z wrote:its the black plastic bit at the bottom that goes all the way across and underneath your bumper, mine was like yours but I swapped it for the GTi one... definitely recommended mod! 8)
is it the strip below the foglight on ures (its chunkyier than above it?)
Alex
way_z
Drives: 6n2 1.4 TDI
Post by way_z »
not sure what u mean alex but here's a pic with the gti lower lip circled... u can swap yours for a gti one and when u do then its easier to take off the lower centre grill :P
alexperkins
Site Admin
ahh i get u now :) did u have to get yours sprayed the right colour? and also was it from VKG? if not where and how much :P
Cheers,
Alex
way_z
Drives: 6n2 1.4 TDI
Post by way_z »
nah i didn't get it sprayed the same colour, the gti's dont have it painted either as standard... its a preference thing ppl do, im still unsure whether i want to or not :?
i got it brand new from Euro Car Parts for about 30 or so quid, not bad at all and makes quite a difference, especially once you lower it!
alexperkins
Site Admin
is it easy to fit then? ahh no paint that makes it much easier :D
Alex
way_z
Drives: 6n2 1.4 TDI
Post by way_z »
its pretty simple but not neccessarily easy (if that makes any sense!?)..
its just a matter of taking off 1 screw under the wheel arch near the bottom on either side of the car and then just yanking the old moulding off! i would suggest getting hold of the gti splitter first so that u can see where it clips in and then just a matter wedging in a screwdriver again, once unclipped it slides outwards... putting the gti splitter back in is a bit fickle, problem i had is once i got one side in the other side would pop out!? i got there eventually tho and then just screwed it in!
alexperkins
Site Admin
ahh nice should be easy now uve told me and ye it makes sense :P. its all good things i could try - you can do anything to car, you just have to have to money to afford it!
Cheers,
Alex
