When should the Exhaust Gas Recirculation valve operate?
When the engine is hot, cold or as required?
I have a 1.4 16v
Thanks.
EGR valve
Okay, next question - any ideas why mine doesnt work then?
When i have the vacuum hose connected to the EGR valve; as the engine gets to running temperature, it cant hold idle and stalls.
If i disconnect the vacuum hose the car runs ok(ish)
Which temp sensor, if any, does the EGR valve take a reading from?
Nick.
Nick.
jakethesnake
