is my head gasket done
right went out to do so winter checks to the car eg anti freeze sqooshers and oil, took the cap off am noticed the oil cap had a bit of mustard lookin gunk on the cap, it mixed fine with the oil when rubbed my fingers with it, was not on all of the cap just a small area, my water level is fine and not went down so any clue what it is. and how will i no if its head gasket etc and whats best to do is the head gasket goes does it damaged the engine any more and will the repair bill be alot more
mysteryboy
The_phat_controlleruk
I've heard the same thing (short journeys), my head gasket was done last year and still suffers from cream occasionely. Just keep checking your coolant level, how's the temperature gauge? Mine used to run hot(more than normal) when idle, then cool right down when on a motorway, this was an indication of my h/g on the way out. The water pump was the final straw, it gave up.
its quite normal, as the rocker cover is made of alloy usualy and that causes condensation, take it on a long run, check your water level, if the header tank lid blows sky high you got probs. also squeeze the pipes going into and out of the rad they should be squeezable, not rock hard, after the long run your oil cap should be black as the oil will have gone to temperature.
