[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 Best Oil For My SE 1.4 16v 75bhp - UK-POLOS.NET - THE VW Polo Forum
My car needs oil changing and what is the best one to use. Don't mind spending a bit extra for something very good. I tend to do short trips as well as long motorway journeys
After having many problems, I recommend you use only quantum oil that VW sell. Whilst other oils meat the specs, I had trouble with the oils breaking down, causing it to come out the breather. Since I used the quantum oil, no problems.
The worst oil was magnatec advanced. Its to do with the synthetic blending. Whilst the viscosity is correct, it starts to break up under high pressure somewhere in the engine, it doesn't work well with the upper cylinder lubrication design on the polo. I was chasing the problem round all over and it was just the oil!
well to get under my car i had to use the jack that you get in the boot first to lift it up a bit, then i used a proper hydraulic jack which wouldn't fit underneath. The oil filter is easy to get to and change, it is just in front of the engine near the altenator as mentioned above
You need a socket, and it has to be the right size, or else it will tear off, then you are screwed.
It sometimes is tight. Remember to smear some fresh oil on the rubber seal when you place the new one on, and do it up by hand. If it leaks, then and only then nip it up a little further. The rubber seal should do the sealing, not by just raunging it up!
