A clichéd girly intro...with chugging problems.
Chat about your MKI or MKII Polo (86 and 86F)
Chally_Rai
Sponsor
Post by Chally_Rai »
Polo Paul wrote:Mine used to tick every now and again, its normally a sign that the oil isnt getting around the engine as well as it could and a sign that the oil and filter need changing. Also if the car is just doing short runs that will be why your batter has gone down, short runs, lots of stalling equals a dead battery
oh really? i thought giving her short runs would be better than nothing? I have a hard time getting people to take me out in her...she wouldnt start today either so my friend said he'd try and get a battery from somewhere...
i think i should start reading that manual!!!
my ex says that the clicking was probably the exhaust cuz of the heat but i duno...Ive not had a look at it yet cuz its always so dark by the time im back from work but i shall have a poke (and probably make it worse!) tommorrow....after my mock test....oo er
:shock:
Mk2Adam
Post by Mk2Adam »
i'd say it'd be best to just splash out on the new battery :wink:
Chally_Rai
Sponsor
Mk2Adam wrote:i'd say it'd be best to just splash out on the new battery :wink:
Really?....I wonder how much they are...
googles it... 30-40 squid.... i reckon i could manage that...but Ill see if my friend finds me a battery first and then ill get a new one in the new year if need be, if he doesnt get one though ill get a new one now.
Is it best to do it online?
Any particular make the best? ive just looked real quick and theres numax and varta
This forum is fantastic :D hehe
Chally_Rai
Sponsor
Poor starting but being able to bump start is probably the battery if it is old or hasn't been used in a while. Also grab a new fan belt (alternator belt). You will need a belt dressing too, I use belt slip and recommend it, only costs £3.00 a can.
New spark plugs, ignition coil and HT leads wouldn't go a miss either.
Does this sound about right? lol.
I def need a new battery, the poor thing is completely dead..
412770712
LION BATTERY TYPE 007 36Ah 175/300 212Lx175Wx175H 0/1 B13
£33.00 £33.00
408771280
BOSCH SUPER WR78X BOSCH SUPER WR78X
£4.47 £4.47
413110030
IGNITION COIL BMW/CIT/AUD/MER/PEU/ REN/SEAT/SKO/VOL/VW/ALFA/FIAT/FORD
£14.70 £14.70
413440471
IGNITION COIL VW/AUDI PO/GO/JE/VE/T4/PA/A80/A4
£27.95 £27.95
409440090
IGNITION LEAD SET
£13.99 £13.99
401440451
ALTERNATOR 55AMPS PO 1.05-1.3D -94 GO/JE 1.3 -91
Redeemable Surcharge of £20 per item included
£71.43 £91.43
Saint Jimi
Ticking?
Post by Saint Jimi »
If i Know my polos, a constant ticking will usually be your tappets not adjusting properly, on an L reg they should be hydraulic (self adjusting) but if there isn't enough oil, or the oil is s**t, or even too thick I have found they will not adjust right so they tick.
If oil doesn't help, tappets are about 8 quid each and you take the rocker cover off to change them.
Am I right boys and girls... I'm open to correction.
Chally_Rai
Sponsor
I havent noticed it ticking again....but i will check that out again as soon as..
FFS I hate this bloody car!
borrowed battery in....it is now aparent that it is either the alternator, the ignition thing i forget what its called or me leaving something unknown on. My nextdoor neighbour is going to check it out with me in a bit to test the alternator and ignition thing. Just had to jump start it to go to argos....then turned it off and then tried turn it on again 5secs later to check it would start but it just went chhhhhhc hhhhhhh...
So i reckon the alternators not charging it...cuz if it was there should have been enough volts for the ignitiony thing to work right? cuz its volt sensitive? and if the ignition was properly broke it wouldnt have been working the past 3 times when it ran absolutely fine....
Hmph!
this is what happens when you have a 500GBP budget and only spend 350GBP... at an auction...
:roll:
Nah its all good, just teething problems :wink:
Chally_Rai
Sponsor
tis the starter motor...
Chally_Rai
Sponsor
Which I am going to attempt to change myself once i get the new one :?
