Heater
Pedro_Hilario
Heater
Just noticed another problem i'm experiencing:
I have no hot air coming out of the vents. I have a steady and strong flow of air, so its not obstruct. I also changed the polen filter a month ago...
All i get is cold air, no matter how i rearrange the buttons on the heater panel.
Thoughts?
PG
Thoughts?
PG
Pedro_Hilario
Hehe,Dee-vub wrote:Why would you want hot air coming out when you live in portugal???
Exactly because of that particular fact. I'm used to hot weather. It's 10 degrees outside and i can only leave the house with gloves, scarf, etc etc!
What can i say! The first time i went to london I almost froze to death!!
But back to the car.
By heater motor do you mean the blower? this little thing here?
But if the air flow is strong, i presume this is working fine. But i'll check it out.
What are the other things i should check? I read around and people talked about the thermostat and flushing the coolant. Care to develop on the topic?
Thanks,
Pedro
Pedro_Hilario
Hey,alexperkins wrote:I think there is a heater element or some mechanism which diverts the hot air from the engine - worth checking that out too
Cheers,
Alex
Thanks, that should be it. I've checked the blower and it's fine.
But where is that heater element located? Does anyone knows?
Oh, and how do i check the thermostat?
Pedro
Try living in the north of scotland matePedro_Hilario wrote:Hehe,Dee-vub wrote:Why would you want hot air coming out when you live in portugal???
Thanks,
Pedro
Good luck with fxing the car.
Pedro_Hilario
Well, seems like i have to check the heater matrix!
And by what you guys say, i'll be over by summer time!
Rich16v, could you give out some pointers on how to check the heater matrix?
What should i do? Disconnect the two tubes, take it out and clean it, check for leaks...what?
And i'll also check what the Haynes manual has to say about this!
Thanks,
Pedro
Thanks,
Pedro
ill get you some photos of mine as im currently doing it..I noticed as i had a funny smell coming through the vents (coolant) and not a lot of heat.Plus i was losing water from the header tank.You can disconnect it by taking the piping of that goes through the bulkhead and simply bypass it which is how i ran mine like that but decided to sort it eventually.If you have to fix it you gotta take all the dash out/steering wheel and airbag/the lot really,as its right behind your dash.Like i said ill get you some pics shortly..
Nuclear_Tom
