[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 Alloy wheel centres help needed!!! - UK-POLOS.NET - THE VW Polo Forum
you can buy a set of 60mm stickers from ebay, that go on top of the original centre caps. If you want them to fit in perfectly with your rims, the best idea would probably be to sand down like 1 or 2 mm off the top of the cap, however you can just stick them on top.
