Offsets...
ziyaad
Offsets...
Post by ziyaad »
Will a wheel with these sizes fit on a 6n2 without adaptors? They're 4x100. Rim Width: 9J.
Rim Diameter: 16 inches.
Offset: 15
im not lowered but have plans to go down as much as possible on coilies soon as alloys are on.
Dee-vub
Post by Dee-vub »
Yes they will fit but will completely ruin your arches if you lower alot. They wiull stick out a fair bit mate! And due to being 16's aswell, i just dont think it'll work.
They will defo go on tho.
vdubit
Post by vdubit »
I have 9x15's on my 6n2. I have ET25 offset, which makes one hell of a differance. Using 215/45/15's and wound down 55mm scrubs a bit, but not major bad. I used to have 8x15's on the back using the same size tyre, they scrubbed a lot worse as they were ET20. I know the theory behind it is wrong, but because the tyres are now stretched and the central pattern is 5mm further in, scrubbing is a lot less. So if you can, get ET25.
