hi
wen i had my last zorst from powerflow it was sound but wen i lowered it , it rattles wen at low revs ,
i now have a new zorst from gt3 exhausts , and the problem is still there ,
and ive realised that it rattles because the zorst goes over the axel and its really anoying ,
so does anyone else have this problem and if i can do a little boj job to stop this rubbing ?
also my new mods this month
: angel eyes removed ,
:put standard headlights bk on
: front cluster indicators
:new zorst 4 in oval
:new spoiler
:bonet extender
to be honest i fink the standard lights and clear indicators look loads better than my old angel eyes , wot does anyone else fink ?
i will post updated pics soon
daz1245
zorst problem
vdubyabush
my exhaust also knocks on the rear axle
Its not a powerflow mind, or any other fancy razmataz. Its juts a savage backbox.. i think.. or rage... i forget....
Either way ti does this exavct same thing! though more so when i got lots of weight in the back then any other time.
Id be muchly greatful if anyone can suss this aswell!
The_phat_controlleruk
solidsponge
Found the problem with mine and may be the same with everyone else's. With the standard rubber hangers on the rear the silencer sits to low, especially if it's been lowered. Go over a speed bump and the exhaust whacks the rear axle. The solution I have come up with is to ditch the rear hangers in favour of a ghetto style job. I made up two metal plates and drilled holes in each end to match the bolt holes for the original hangers. I found some rubber pipe that was just the right diameter to slide onto the hangers of the new exhaust, I then bolted this onto the body work. The silencer is now secure (bast*^d does not move at all), does not rattle and sits about an inch and a half higher than normal.
